Using quoted fieldnames
cjmoore
In a TOracleDataset is there a way to get it to use quoted fieldnames in the SQL it generates on a post (insert or update)?
The problem I have is one of the field names in a table is mixedcase (the rest are uppercase) and I get an invalid fieldname error when an update is posted.
TIA
Cary.
[This message has been edited by cjmoore (edited 02 August 2001).]
The TOracleDataSet does currently not support mixed case column names, unless you handle all DML yourself in the OnApplyRecord event handler. This may be a lot of work though, if all your tables have mixed case column names.
You could alternatively rename the columns, or use a view to change the column names.
I thought that might be the answer, the short-term fix I've removed the field from the Oracledataset's that update it and have added code to apply updates manually.
In the longer term I'll rename the column when there's a major release to be packaged.
Cary.
