I am new in this forum.
I try to use the Feature of user preferences with Connection Context. I want to use it for saving packages in different Folders depend on the Schema where i am.
I am using the following structure of preferences
Files > Directories > Program files (ProgramFileDir) =
System Preferences : = A
User Default Preferences : = B
User c Preferences : = B\C with Connection C*
I if I connected with C to any DB , I want the saving program file Directory B\C.
But I only get B. Did I misunderstood the concept?
How I know which Preferences are used with the Connection I actually have?
Thanks for every hint and advice.
amsel
amsel
