Urgent Help
ali.fci
I am a delphi developer and I was in a bad need for a component that connect to oracle server from a client side without installing oracle client on the client side.
I think DOA component will do the job but
when I installed the components and everytime I use any component from the pallet it gives me error
"[Fatal Error] File not found: 'c:\program files\borland\delphi7\DOA\Oracle.pas'"
and i dont know why?
I am using a trial version and if this component will solve my problem I will buy it immediately.
thank you all for your response.
yours
Ali
First of all Direct Oracle Access still requires an Oracle Client installation. As a minimum this can be an Oracle10g Instant Client.
The error may indicate that you are using a Delphi (not DOA) trial version? Could this be the case?
