Uppercase/lowercase problem
Qkxy
In SQL window I start to type this:
1:>strange BeHaViOuR
than I select the last word "BeHaViOuR" and select
Edit=>Selection>Uppercase or Lowercase menu, the text became uppercase or lowercase. Than I press the left arrow key (unselect the text) and press any character the text become unchanged "BeHaViOuR".
PL/SQL Developer version: 7.0.2.1076
Qkxy,
I'll take a pound of whatever you're smoking! :-)
I couldn't replicate this behavior and I'm running the same version.
I pasted the entire line of text into a new SQL window, selected the last word, pulled down the menu option Edit->Selection->Uppercase, then left arrow and typed the letter 'a' (w/o quotes). Nothing strange happened.
Could you be in the southern hemisphere and so the magnetic poles are different? :-)
Good luck with whatever's going on there!
I can reproduce it in the command window and SQL window with all of the plug-ins disabled.
The only difference is that I have to press the right arrow key to deselect the text. If I left arrow key, it puts my cursor in the middle of the word.
Mike
Mike:
Yes, you are right. It is really the right arrow key I have pressed. I'm sorry for the false report.
Marco:
You can reproduce it without arrow key you only have to click with the mouse to the end of the text and type a character.
Stew:
I'm not smoking and I'm in the northern hemisphere.
I noticed that if the Editor/Keyword preference is "Unchanged", the problem doesn't show up.
I have it as "Uppercase" normally and the problem does show up.
Mike
