Unicode Display in PLSQL Developer
hi,
i have insert data in oracle like following
insert into test(name) values('\u062c\u0627\u0648\u06cc\u062f\u0020\u0645');
What i want now is that when i query from PLSQL Developer it shows me unicode in Arabic.
My PLSQL Version is 7.1.5.1398.
Second i want that when i export query result to CSV it should shows Arabic character. Currently its showing output like following
Regards,
imran
Oracle does not recognize the backslash as an escape character in strings. The string '\u062c' is literally a string made up of 6 characters. This is why you are getting the output you see.
An easy way to get what you're looking for on Oracle 9i and above is to use the unistr() function:
insert into test(name) values(unistr('\062c\0627\0648\06cc\062f\0020\0645'));
This function parses the string and gives you the characters you want.
