Unable to open *.pkh and *.pkb Files in a Project
Hi all,
i have a problem with my pl/sql developer Version 7.0.2.1076 (MBCS). I have added .pkh as package spec's and .pkb as package body's but i can not open these files from the project.
anyone can give me a hint what can i do?
regard christian
This seems to be a bug og the "Add file" button on the "Project Items" toolbar. When adding a file though "Project > Add to Project", it works okay.
We'll fix it.
It also works if you drag the object from Windows Explorer to the PL/SQL Developer button in the task bar and then to PLSD desktop.
It still doesn't work if you add files from the project items' toolbar. I've tried with custom extensions, such as: afffload, aflvmlu, and so on, running 7.1.1.1350.
Regards,
Gustavo
