Unable to create macro for Comment Lines Plug In
Hi, Marco and everyone.
I'm on version PL/SQL Developer version 10.0.5.1710. In previous versions, I was able to create macros that could open new SQL windows, open the "Report" menu and, most important, run the Comment Lines plugin. When I try to record the macro now, I did as before - starting the recorder, using only keyboard commands to go to file menu, down arrows to selection, then down arrows to where the comment lines option is and enter. But now, when I finish recording and look in the library - the unnamed macro has no keystrokes. same with other things I try to record that require the control or alt key. Any ideas? I am using Windows 7. Thanks
