i'm using version 6.0.5.931 of plsql developer with oracle 10g.
my first problem is that the sql editor and package/procedure editor gets into these deadlocks when tring to retrive a list of object (using "owner." + F6). the only way to relese him is to kill the session in the database. in this case tou get an "end of communication channel" and you must reconnect.
my second problem is that plsql developer just wont minimize somwtimes. the only way to reach the desktop is press winkey + D and even then, it will pop up with every window you maximize.
is there a good solution for that issues ??
Thanks , Haki
Thanks , Haki
