Two things that need improvement in PL/SQL Developer
iraklisvai
Suppose I want to connect to
username1/password1@new1
and without opening another PL/Sql Developer to a different Database for example
username2/password2@new2
If I have Toad as an IDE, I can see triggers and procedures of both schemas.
With PL/SQl I can't.
Another issue,
If I open a new SQL Window, and write
select * from TableA;
Then I write
select * from TableB;
And I want to run only the second statement, I have to mark it with the mouse and press F8,
which is a bit inconvienient. With Toad, if I put the cursor in statemnt 2, then I can run it.
With PL/SQL Developer I have to open a new SQL Window or hightlight it and press F8
Thank you.
Regarding your 2nd issue, you can just check the setting:
"Preferences" - "Window Types" - "SQL Window" - "AutoSelect statement"
Now you just put your cursor within the sql you want to execute and press F8.
