W wgp3 Member Jan 23, 2007 #1 Hello, Can someone tell me how to keep: for i in 0.. loop end loop; from showing up every time I type "for" and then space? I use "for" in "for update" a lot and this gets annoying. Thanks,
M mike Member³ Jan 23, 2007 #1 Do you have the TexType plugin? If so, that might be what is doing that. To change it: 1. Go to tools/configure plug-ins. 2. Select TexType and then select the wrench. 3. Under the Shortcuts tab, uncheck the "for" entry. Mike
