TSequenceField doesn't work with AppServer?
wyverex
When using TSequenceField on a local DB all works fine when appending new records.
But when the OracleDataSet resides in a RemoteDataModule on an app server and is connected to a TClientDataSet via a TDataSetProvider, the sequence number is not generated and the corresponding field in the client data set is filled with a null value.
How can I fix this? Or do I have to implement my own sequence number generator?
thx in advance
The SequenceField will only work if TDataSetProvider.ResolveToDataSet is set to True. Otherwise the insert statement is generated by the TDataSetProvider, bypassing the sequence property of the dataset.
