Trace Output
jlcox
I had a very long-running job that generated quite a bit of trace output. When I bring up the trace tab, PL/SQL Developer stops responding for a very long time then finally returns with an out-of-memory error message. Clicking the delete button on the trace tab generates several Oracle errors about tables not existing.
How can I delete the trace output?
delete sys.plsql_trace_events e
    where e.runid in (select r.runid from sys.plsql_trace_runs r where r.run_owner = user);
  delete sys.plsql_trace_runs r where r.run_owner = user;
  commit;
This will delete all trace runs of the currently connected user!
Still not sure what's causing the errors. Clicking on the "delete" button on the trace tab generates these errors in a dialog box:
ORA-06550: line 4, column 14:
PL/SQL: ORA-00942: table or view does not exist
ORA-06550: line 4, column 3:
PL/SQL: SQL Statement ignored
ORA-06550: line 5, column 14:
ORA-06550: line 5, column 3:
I've tried this on several different systems (development, test, production) and always get this message. I've run the profload.sql, proftab.sql, and tracetab.sql scripts as SYS.
