Tortoise is not SCC compliant?
lieberlady
I installed Tortoise, but it doesn't show in the list of projects available. Source Safe, Igloo, and PuskOK do. Does that mean it's not SCC compliant?
On a related note, I can't use Igloo because it only takes pserver, not ssh. My installation requires ssh. Now I'm trying to get PushOK to work.
I had installed Igloo and it didn't display the list of files in a directory.
So I installed TortoiseCVS to see if it would work better.
Both VCS interfaces appeared in PL/SQL Developer VCS menu, but whenever I tried to select TortoiseCVS, it kept going back to Igloo, and showing me Igloo-related menus.
Therefore I deinstalled Igloo from my machine.
The problem is that I cannot enable PL/SQL Developer VCS plug-in anymore...
I get a message box : "Could not active plug-in: Version Control Interface 1.2".
I tried to reinstall VCS interface plugin with no success.
Could you help me please?
Avigael
Can you delete (or rename) the following registry section and try again?
HKEY_CURRENT_USER\Software\Allround Automations\PL/SQL Developer\PlugIns\VCS
Let me know what happens.
Hi Marco,
I don't get the error anymore after updating the registry when enabling PL/SQL Developer VCS plugin, but now TortoiseCVS SCC plugin has disappeared from the list of "Available Version Control Systems"... therefore I don't have any VCS at all.
I tried to reinstall TortoiseCVS + PL/SQL Developer VCS plugin, but TortoiseCVS SCC plugin remained invisible.
Cheers,
Avigael
All SCC Providers should be listed in the following registry section:
HKEY_LOCAL_MACHINE\Software\SourceCodeControlProvider\InstalledSCCProviders
Can you verify this?
This key contains a string value where variable=value=empty string!
Is there anything I can manually fix?
Thank you.
