Jonas Malmsten
I'm developing a component having a TOracleSession property. When this property is assigned the component information is updated if the OracleSession is connected. I would also like to update the information when the OracleSession is connected (incase it wasn't from start or if it was disconnected and then reconnected).
Is there a way to implement this functionality inside of my component (ie making it aware of when the session is connected) without having some external code doing it or using up the published events for the OracleSession?
Is there a way to get hold of the source code for DOA? (If I had it I could probably have found an answer to my problem browsing the source code).
Oh, and I'm using DOA 3.3 for Delphi 4.
