TOracleScript and MERGE
aik hooi
Dear Marco,
Can TOracleScript parse and recognised MERGE sql syantax ?
From my testing, it seems not recognised MERGE sql command which was introduced in Oracle 9i.
Regards
Merge is indeed not recognized as a SQL statement. We'll add it. As a workaround you need to recognize this in the OnCommand event, and pass the statement to the server.
when I put this statement in TOracleScript, can the component detect this statement as a whole to be pass into onCommand event ?
merge
into contract a
using customer b
on (a.cust_id = b.cust_id)
when matched then
update set a.desc = b.profile,
a.customer_name = b.cust_name,
when not matched then
insert values ( b.profile,
b.cust_name);
And, do you have any idea when MERGE feature will be included in your next release ?
Reagards
Aik Hooi
Good question. I think it would need to be a one-liner.
That would be in a few weeks. If you let me know your Delphi/C++Builder version, I can upload a patch for you.
It would be great if you can upload the patch to me. I am using Delphi 7 and Direct Oracle Access 4.1.0.7. Thanks
Email me at aikhooi99@gmail.com
Regards
Aik Hooi
We'll need to roll this into the final 4.1.1 patch release, which includes some additional fixes. It will be available in one or two weeks.
Dear Marco,
I used the same SQL Syntax to test the parsing of merge statement in TOracleScript.
merge
into contract a
using customer b
when matched then
b.cust_name);
When TOraclescript reach the merge statements, it is able to detect that it is a nonSQL type but only returns "merge" as a command.substitutedtext property and skip the rest of the lines below.
I uninstall and reinstall DOA but it still doesnt work.Hope you can further investigate. Thanks
Regards
When I try this statement in a script in 4.1.1, it recognizes MERGE as a SQL statement, and sends it to the server. In 4.1.0 and earlier, it would not have been recognized as a SQL statement.
