TOracleQuery.First
ASDD
We have installed DOA 4.0.0 components (Trial version). In order to use scrollable query possibility we also have installed Oracle 9.2.0.4 EE (and clients respectively) in according with your DOA/news webpage information.
In Delphi project we set the property
TOracleQuery.Scrollable in TRUE;
But after executing the query (Execute), when we try to call First method, the exception raised:
"TOracleQuery.First only possible on Oracle Net 9.0 or later."
What can we do in this situation?
Thank you.
Thank you for the answer.
We are sure that Primary Oracle Home is 9.2.0.4
in addition to yesterday information:
during the latest experiments we have recognized that
if TOracleQuery is based on one table only (select * from table1) - all works correctly, but if it's based on more than one table (select table1.name, table2.name from table1, table2 where table1.id = table2.id) the exception previously specified raised.
Perhaps it will help to understanding the problem.
Thank you.
That would be strange. The actual SQL should not matter at all. Can you send me something to reproduce this?
In continuation:
TOracleQuery.SqlText :=
SELECT
b.comments,
a.data_type,
a.data_default,
a.nullable,
a.column_name
FROM
all_tab_columns a,
all_col_comments b
WHERE
UPPER(a.table_name) = UPPER(:TableName)AND
(b.table_name = a.table_name) AND
(b.column_name = a.column_name)
ORDER BY
b.comments
We use this syntax for selecting descriptions (such as comments, data_type etc.) for all fields of any table sending into query through :TableName variable.
property Scrollable is True (set in design time)
DeclareVariable('TableName', otString);
SetVariable('TableName', );
Execute;
after this exception raised.
Thanks for your patience.
