ToracleEvent problems
joet
I'm using a TOracleEvent to pass an alert on an insert trigger in ORacle 9i 9.2. It is a 2 node RAC cluster. I'm geeting some sporadic results. Sometimes I receive the alert sometimes I don't. Does anyone have any thoughts on why this might be?
I'm using direct Oracle access 4.0.6 with C++ builder 6
Joe
the two transactions I discussed in my previous email are about 6 seconds apart, one successful the other not, do I need to do anything special in my service to queue these transactions if they are comming that quick? Could it be busy handling one transaction and miss another?
You can indeed miss alerts if it takes too long to process them. If you need guaranteed delivery, use AQ instead.
AQ = Advanced Queuing. It is implemented in Oracle through the dbms_aq and dbms_aqadm packages. The Oracle "PL/SQL Packages and Types Reference" describes these packages (and their types) in detail.
Direct Oracle Access 4.0 supports AQ through the TOracleQueue component.
When trying to compile the example showing AQ support I get the following error. Any help? A TOracleObejct require the Direct ORacle Access Obecjt version.
I have the standard version, I just purchased the object version, is there an upgrade available? How can I upgrade my standard edition to object edition? Do I have to uninstall and resinstall or is there an easier method?
Joe
thanks Marco,
But you didnt really answer all my questions. Is there an upgrade path from the non object version to the object version? Or am I required to purchase a new version?
Joe
Sorry, I missed that. There is indeed a standard-to-object upgrade available. It costs USD 50 per license.
I was in a hurry and bought the object version seperately. can you halpe me get a partial refund please?
Joe
I have defined the following object. When I dequeue it and try to get the data via the TOraclequeue->Payload->GetAttr(); It hangs my service. IS there some step I'm missing? I get the MessageID ok but any data accessed via getattr causes issues. I noticed a queuetype but I can't seem to set that. does it default to qtObject?
create type feature_package_type as object
app_feature_id number(10),
app_id varchar2(7),
service_no_id varchar2(7),
service_no varchar2(20)
fprintf(ptr, "Calling Dequeue Function%s \n", DateTimeToStr(Now()));
OracleQueue1->Dequeue();
fprintf(ptr, "Message received: %s \n" , OracleQueue1->MessageProperties->MsgId);
fprintf(ptr, "App feature_id = %s \n", OracleQueue1->Payload->GetAttr("app_feature_id"));
Did you set TOracleQueue.Threaded to True? In that case the Dequeue call will merely spawn a thread, and the OnThreadDequeued event handler will be called when a message has been dequeued.
The QueueType property reflects the type of the queue. You cannot set it, since it depends on the QueueName property.
Marco,
Yes I have tried setting the Threaded property to true. My onThreadDequeued evnt handler looks like this.
fprintf(ptr, "Message received: %s \n", Sender->MessageProperties->MsgId);
fprintf(ptr, "%s \n", Sender->Payload->GetAttr("app_feature_id"));
this causes the service to hang. If I remove the line fprintf(ptr, "%s \n", Sender->Payload->GetAttr("app_feature_id")); it works fine. I've included the code I used to define my object, create and start my queue and to queue up a sample message. What am I doing wrong?
app_id varchar2(7),
dbms_aqadm.create_queue_table(queue_table => 'fea_package_queue_table',
queue_payload_type => 'feature_package_type');
dbms_aqadm.create_queue(queue_name => 'feature_package_queue',
queue_table => 'fea_package_queue_table');
dbms_aqadm.start_queue(queue_name => 'feature_package_queue');
commit;
DECLARE
queueopts DBMS_AQ.ENQUEUE_OPTIONS_T;
msgprops DBMS_AQ.MESSAGE_PROPERTIES_T;
msgid RAW(16);
my_msg feature_package_type;
my_msg := feature_package_type(1234567890,1234567,'123abc','abc123','2486564210');
DBMS_AQ.ENQUEUE ('feature_package_queue',
queueopts,
msgprops,
my_msg,
msgid);
END;
Commit;
Marco,
This code works fine in an application. It only causes issues when I try to include it in a windows service. Can you see if you can reproduce this issue on your end?
did you ever have a chance to look at this? this works fine in an application but when used as a windows service it hangs! also any progress on the situation where you lose a database connection and want to reconnect without recreating the queue?
Joe
