TOracleDirectPathLoader and Dates
BobGeezer
Hi All,
Using the loader, we want to load a row with integers, strings and dates/times/timestamps.
Strings and integers are OK. In desperation, we're trying to assign the date values as strings. Is there a simple example of this? Is there any example of dates in direct path loader? The DirectPath project shows only integers and strings; it omits to demonstrate the date or timestamp types.
The field in question is called INSERTDATE TIMESTAMP(3) nullable.
We get error:
ORA-26093: input data column size (19) exceeds the maximum input size (8)
The 19 is the length of the date/time string we supply. Presumably, the 8 is some Oracle date storage type (or maybe a real?)
We have set the column .Datatype to dpString and the .DateFormat to 'DD/MM/YYYY HH24:MI:SS' and the value passed in is '24/06/2002 16:36:15' (without the quotes) so all looks correct, but still this error arises.
Timestamps are not the same as dates. You will have to pass the timestamp values in the format specified in NLS_TIMESTAMP_FORMAT. To force an application specific format, execute an "alter session set nls_timestamp_format = [format]" command.
Hi Marco or anyone who's used dates and times,
I've tried loads of things with direct path timestamps and got nowhere. I then discovered that if we accept the limitation of "no milliseconds" then a "date" column will suffice.
However, with ODPL, I find there is no date type (only dpString, dpInteger, dpFloat, dpBinary) so I'm inserting the date/time as a dpString once again.
This gives error:
ORA-26093: input data column size (20) exceeds the maximum input size (8)
This happens when I'm tring to set the date to '17 Oct 2006 17:06:23' using date format 'dd mmm yyyy hh24:mi:ss'. Where am I going wrong please?
s1 := FormatDateTime(
'dd mmm yyyy hh:mm:ss',
qryDataSrc.Fields[Col].AsDateTime
odplLoader.Columns[Col].dateformat
:= 'dd mmm yyyy hh24:mi:ss';
I then make a permanent copy of s1's value so that it is still there for the .Load() method. I then call SetDate as follows:
odplLoader.Columns[Col].SetData(
Row, @strg.str[1], length(s1)
...where strg.str is the permanent copy...
Please, please, please can you find a single working Delphi example of direct path with dates and times stored in one field?
As stated before, date settings do not apply for timestamps.
Did you set the NLS_TIMESTAMP_FORMAT as suggested?
Hi Marco,
Yes, I've tried every possible combination of date formats and every possible NLS_TIMESTAMP_FORMAT and NLS_DATE_FORMAT I can think of including simply using 'DD-MM-YY' ignoring the time and I can't get it to work.
I've given up and I'm now trying to "fit in with Oracle" and use truncated dates: 24-06-02
..but now I get a new error message saying:
ORA-26041: DATETIME/INTERVAL datatype conversion error
Please, has anyone an example of how to direct load dates - even without times? I'm past caring now. This has stalled me for a whole week. It really can't be that hard can it?
Do you want example code?
It turns out that the Direct Path Loader does not use the session's NLS_TIMESTAMP_FORMAT, but always uses the value in the registry. This can cause confusion of course, and I wonder if this might actually be an Oracle bug.
Anyway, here is a working code example:
procedure LoadTimeStamps;
type
  TSRecord = record
    value: string;
const
  NumRows = 2;
  TimeStamps: array[0..NumRows - 1] of TSRecord =
    (id:12; value: '19-OCT-2006 10:55:23.123456'),
    (id:23; value: '20-OCT-2006 11:28:11.314159')
var
  Session: TOracleSession;
  Loader: TOracleDirectPathLoader;
  Column1, Column2: TDirectPathColumn;
  ts: Integer;
  // Create a session and logon
  Session := TOracleSession.Create(nil);
  Session.LogonUsername := 'scott';
  Session.LogonPassword := 'tiger';
  Session.LogonDatabase := 'chicago';
  Session.LogOn;
  // Create the loader and setup the columns
  Loader := TOracleDirectPathLoader.Create(nil);
  Loader.Session := Session;
  Loader.TableName := 'TS_LOADTABLE';
  Loader.GetDefaultColumns(False);
  Column1 := Loader.ColumnByName('id');
  Column1.DataType := dpInteger;
  Column2 := Loader.ColumnByName('value');
  // Set the timestamp size so that the string format fits
  Column1.DataType := dpString;
  Column2.DataSize := 40;
  // Load the records
  Loader.Prepare;
  for ts := 0 to NumRows - 1 do
    Column1.SetData(ts, @TimeStamps[ts].id, 0);
    Column2.SetData(ts, @TimeStamps[ts].value[1], Length(TimeStamps[ts].value));
  Loader.Load(NumRows);
  // Done
  Loader.Finish;
  Session.Commit;
  Loader.Free;
  Session.Free;
This code assumes that the NLS_TIMESTAMP_FORMAT inthe registry matches the values (e.g. DD-MON-YYYY HH24:MI:SSXFF). It also assumes that you have a table like this:
CREATE TABLE TS_LOADTABLE
  ID    NUMBER(4),
  VALUE TIMESTAMP
