TOracleDataSet in Frame
i have a DetailOracleDataSet in a Frame,
after this frame created in runtime,
i set DetailOracleDataSet.Master= MasterDataSet,when i applyupdates,error occurs,DetailOracleDataSet have two same
record,why?
Best regards
AC
Can you show us the code that applies these updates?
sorry, my code is very long, so in brief
the master dataset is in my
main form and detail dataset in frame.
if i not set detail.master property then
it works,but if i set that,it will
duplicate a same record after i
commit . thx.
Since the records appear twice, I assume that the updates are applied twice as well. Note that if you apply the updates of a master dataset, this implicitly applies the changes to the detail dataset. Could it be that you implicitly apply the updates of the detail dataset in a separate call to TOracleSession.ApplyUpdates?
