TOracleDataSet field editor problem
masfaw
I get AVs when adding or deleting fields from the field editor dialog under the following condition.
1. Add some TFields using the TOracleDataSet field editor.
2. Modify the TOracleDataSet sql statement so some of the added fields become invalid.
3. Now try to delete the invalid fields in the editor. An AV is generated and the fields cannot be deleted. (Adding a field also generates an AV.)
I had to revert back to version 3.4 to continue my work. I hope you can fix this problem soon.
We were able to reproduce and fix this. The fix will be available in beta 2 today or tomorrow.
