Brooks Vaughn
How do I update a CLOB or BLOB ???
I tried the following code and get an error when executing line "LOB.AsString := StringList_WhoIsResults.Text;":
The Error is:
"Project OPP.exe raised exception class EOracleError with message 'ORA-22920: row containing the LOB is not locked'."
Any Ideas how to update the Clob/Blob so it works ???
-Brooks
LOB := TLOBLocator.Create(OracleSession1, otCLOB);
try
with OracleQuery_StoreWhoIsResults do begin
DeleteVariables;
SQL.Clear;
SQL.Add( 'BEGIN' );
SQL.Add( 'SELECT whois_body into :WHOIS_BODY' );
SQL.Add( 'FROM dnc.opp_assignments' );
SQL.Add( 'WHERE ID = :ID;' );
SQL.Add( 'EXCEPTION' );
SQL.Add( 'WHEN OTHERS THEN RAISE;' );
SQL.Add( 'END;' );
DeclareVariable('ID',otFloat);
DeclareVariable('WHOIS_BODY',otCLOB);
SetVariable('ID', WhoIsInfo.Assignment_ID);
SetComplexVariable('WHOIS_BODY', LOB);
Execute;
finally
LOB.Free;
LOB := Nil;
The Error is:
-Brooks
try
DeleteVariables;
SQL.Clear;
SQL.Add( 'BEGIN' );
SQL.Add( 'END;' );
Execute;
finally
LOB.Free;
LOB := Nil;
