Tiling in PL/SQL Developer 12
ckubitsc
Has the option of tiling SQL Windows been removed? If not, can someone point me to the right spot on the ribbon?
I just upgraded from 11.0.6.1796 to 12.0.2.1818 and I'm still at the search for everything (search the ribbon, search the manual, search the forum)
Thanks.
On the "View" ribbon you can select one of the tile options from the "Arrange" list. You must be in MDI (Multiple Document Interface) mode though. In SDI (Single Document Interface) mode this is not applicable.
