MShahrouri
while i was searching for a way to connect to TFS from PL/SQL developer i found this thread "Can PL/SQL connect to TFS" . now the problem is that the operations that require TFS (check-in, check-out,..., etc) is very slow and causing the PL/SQL environment to hang for a while (in some cases it hangs for more that 5 minutes).
do you have any suggestion to overcome the slowness problem.
BTW I have VS2010 installed on one of the machines and TFS operations from team explorer are fast.
P.S.: i'm using PL/SQL developer ver 7.1.5 and TFS 2010
Mohammad Shahrouri
Mohammad Shahrouri
