Hi Marco,
here you go.
1. create promon table
2. create procedure
3. click on proc name and select test to open test window
4. run the test
5. change anything in the proc & recompile
6. PLS-00201 is raised once you try to retest using already opened test window
Regards,
Martin
create table PROMON
proinum1 NUMBER,
proinum2 NUMBER,
proappl VARCHAR2(50),
proserv VARCHAR2(50),
prostat NUMBER,
proprog VARCHAR2(30),
promess VARCHAR2(255),
prodate DATE,
prouser VARCHAR2(30),
protype NUMBER
CREATE OR REPLACE PROCEDURE mza_test
( ac_country_code in varchar2 default 'CZ',
ac_group_name in varchar2 default 'GO',
an_group_end in number default 1023,
an_hier_level in number default 3)
AUTHID CURRENT_USER
IS
lc_country_code varchar2(2) := upper( ac_country_code );
lc_group_name varchar2(50) := upper( ac_group_name );
ln_group_end number(5) := an_group_end ;
ln_hier_level number(2) := an_hier_level ;
type promon_aat IS TABLE OF SYSEL.PROMON%ROWTYPE INDEX BY PLS_INTEGER ;
l_promon promon_aat;
--CURSOR
l_rc SYS_REFCURSOR ;
ln_execute BINARY_INTEGER;
ln_awf_go_cur BINARY_INTEGER := DBMS_SQL.OPEN_CURSOR ;
lc_sql_stmt clob :=
'select cast(null as number) as proinum1,
cast(null as number) as proinum2,
cast(null as varchar2(50)) as proappl,
cast(null as varchar2(50)) as proserv,
cast(level as number) as prostat,
cast(''MZA_TEST'' as varchar2(100)) as proprog,
cast(''START'' as varchar2(100)) as promess,
cast(null as date) as prodate,
cast(null as varchar2(30)) as prouser,
cast(null as number) as protype
from dual
connect by level
