Test window and debug mode
The right mouse click doesn't work in test window when the PLSQL Developer is in debug mode. PLSQL Developer hangs a while and the context menu is shown only a few milliseconds :p . In debug.txt the following is added:
03.11.2005 15:08:31 AddPlugInPopups Start 29
03.11.2005 15:08:31 Browser Extender version 2.0 by Joachim Rupik
03.11.2005 15:08:31 Index
03.11.2005 15:08:31 Table
03.11.2005 15:08:31 User
03.11.2005 15:08:31 Tablespace
03.11.2005 15:08:31 Function
03.11.2005 15:08:31 Package
03.11.2005 15:08:31 Package body
03.11.2005 15:08:31 Procedure
03.11.2005 15:08:31 Sequence
03.11.2005 15:08:31 Trigger
03.11.2005 15:08:31 Type
03.11.2005 15:08:31 Type body
03.11.2005 15:08:31 Database link
03.11.2005 15:08:31 Directory
03.11.2005 15:08:31 Foreign Key
03.11.2005 15:08:31 Primary Key
03.11.2005 15:08:31 Synonym
03.11.2005 15:08:31 Unique Key
03.11.2005 15:08:32 View
03.11.2005 15:08:32 Table
03.11.2005 15:08:32 Comment lines v1.3
03.11.2005 15:08:32 PL/SQL Developer CompareSource Plug-In version 2003/12/03
03.11.2005 15:08:32 Execute current tab v1.1
03.11.2005 15:08:32 Easy Bookmark 1.0.1
03.11.2005 15:08:32 PL/SQL Developer FindAll Plug-In version 2003/11/18
03.11.2005 15:08:32 FTP File Interface 1.1
03.11.2005 15:08:32 Syntax HighLighting (1.1)
03.11.2005 15:08:32 LBC Recall Named SQL
03.11.2005 15:08:32 LBC Table Filter
03.11.2005 15:08:32 TABLE
03.11.2005 15:08:32 VIEW
03.11.2005 15:08:32 NamedSQL Plug-In
03.11.2005 15:08:32 Change Password v1.2 by JR
03.11.2005 15:08:32 PasteOptions 1.2
03.11.2005 15:08:32 PL/SQL Documentation (plsqldoc)
03.11.2005 15:08:32 VIEW+
03.11.2005 15:08:32 MATERIALIZED VIEW+
03.11.2005 15:08:32 PACKAGE+
03.11.2005 15:08:32 PACKAGE BODY+
03.11.2005 15:08:32 TABLE+
03.11.2005 15:08:32 TYPE+
03.11.2005 15:08:32 TYPE BODY+
03.11.2005 15:08:32 FUNCTION+
03.11.2005 15:08:32 PROCEDURE+
03.11.2005 15:08:32 TRIGGER+
03.11.2005 15:08:32 PROGRAMWINDOW
03.11.2005 15:08:32 Remote command Plug-in (rexec.dll)
03.11.2005 15:08:32 Save Bookmarks v1.0 by Joachim Rupik
03.11.2005 15:08:32 Save separate v1.0
03.11.2005 15:08:32 PL/SQL Developer Scale Plug-In version 2003/11/13
03.11.2005 15:08:32 Shift-Tab v1.0
03.11.2005 15:08:32 Shortcuts Plug-In v1.2 by Tiger
03.11.2005 15:08:32 SmartEd 2.0 Plug-In
03.11.2005 15:08:32 PL/SQL Developer Sort Plug-In version 2003-11-05
03.11.2005 15:08:32 StartupOptions 1.1
03.11.2005 15:08:32 Templates v1.7
03.11.2005 15:08:32 User-defined Export 1.0
03.11.2005 15:08:32 Toggle Read-Only v1.0
03.11.2005 15:08:32 Version Control Interface 1.2
03.11.2005 15:08:32 ProcedureWindow
03.11.2005 15:08:32 SQLWindow
03.11.2005 15:08:32 TestWindow
03.11.2005 15:08:32 AddMenu
03.11.2005 15:08:32 AddMenu -
03.11.2005 15:08:32 CommandWindow
03.11.2005 15:08:32 AddMenu Check Out
03.11.2005 15:08:32 AddMenu Check In
03.11.2005 15:08:33 AddMenu Check Out r
I use the actual version 6.0.6.947. Maybe it's because of the plugins? In normal mode, everything is OK, only in debug mode right mouse click doesn't work. Therefore it's not really a problem.
