Templates question.
Is it possible to create a template where the a second dropdown changes depending on a first one. For example with tables and fields. Selecting a table in the first dropdown will list all the fields of that table in the second dropdown.
Cheers
This is currently not possible. In version 6.0 we will ad this capability though, and the syntax will probably be similar to the syntax of the substitution variables of the SQL Window and Report Window.
