JaedenRuiner
Howdy,
I'm rather new to Pl/SQL Developer, and loving every second of it. I had always found SQL to be so tasking because I'm a programmer and used to modern IDE's, and most SQL was not exposed to me in such a fashion.
Anyway, I am finding out about these Templates, and they are awesome, because a lot of my daily tasks involve repetitive SQL design query design, so a template that allows me to plug in a few of the values is awesome. However, I am curious about a few things, so with my effusive rambling done i will get to the point.
- Multiple Variable Check
Note that you can create multiple program units in one template by separating them with a line with just a slash (/) character. This way you can create a templates for a package specification and body in a single program file. - New Line / Multi-Line input
Code:select * from table where field in ( '336', '167', '8335', '485', '4331', '4878', '4834', '4852', '4890', '4893', '8381', '4834', '481', '48', '480', '47' ) Template: [+Values="(table.field in ("] [Values] [+Values=") )"]
