Anna
Hi, since I received my new computer and installed PL/SQL Developer a couple of months ago, my tab key does not work for indenting one line of text or maneuvering around dialog boxes. It does work to indent several lines of code when I highlight them though. I thought this might fix itself with the new version, but it didn't. It's also not my keyboard because the tab key works normal in my other applications (ex., Textpad).
Obviously this doesn't impede me from working with the application everyday, but it is a bit annoying. If anybody could give me a tip for figuring this out, I'd appreciate it.
My preferences for tab are:
Indent: Automatic on, Step = 3
Tabs & Wrapping: Everything off, just Tab size = 3.
(My colleague has his set up the same, and his tab works).
Anna
Anna
