Once more (sorry for spam, I need to understand what is going on):
Please share your experience in working with SQL window (I used SQL Navigator before and had no such problems).
It is often needed to *quickly* switch between code and results panes with *maximizing* it.
I cannot find this possibility.
If I drag the border between panes down then next query results are not visible and more dragging or clicking is needed.
Other ways I found are also inconvenient and not quick enough.
So main point is quick *maximizing* a pane for better writing the code or viewing results and restoring it back
(SQL Navigator has two special buttons for it on each pane).
Please give your advice.
Regards,
GriR
