Suggestions for Connection Manager
Seems the formatting buttons are not working.
Regards
Stian
- Autosave connections. If PD crashed I loose all new connections. So I have to manually export the connections every time I create a new connection.
- Create root folders. I was able to do this by manually editing definitions in file and importing.
- Clone/copy existing connection. We have many users/schemas in our database and need 3-5 similar connections for every database.
- Inherit color from parent folder.
- Import/export connections to Oracle SQL Developer keeping same folder structure if possible. We have a mixed environment with many developers/DBAs using SQL Developer.
Regards
Stian
