Suggestion for connection list
Bert Gombos
I have long connection history. Please make an option which devides items in it into submenus by database.
Thanks.
You can organize things by defining connection folders (Tools > Define Connections). For example, if you define a folder named "Chicago" and enter "chicago" in its database property, all recently used connections for this database will automatically appear in this folder.
You can also use wildcards. For example, if you enter "prod*" in the database property, all connections for databases that start with "prod" will automatically appear in this folder.
