Substitiution varibles concatenated by backslash
You will first need to execute:
SET ESCAPE OFF
Otherwise the \ will be treated as the escape character. This should be the same in SQL*Plus.
Thank you very much for this hint. So only the default settings seem to be different between sql*plus and the command window in plsql-dev.
Regards
Not according to the SQL*Plus documentation:
SET ESCAPE
Defines an escape character you can use before the substitution character. The escape character instructs SQL*Plus to treat the substitution character as an ordinary character rather than as a request for variable substitution. The default escape character is a backslash (\).
Maybe it's a SQL*Plus bug?
