I am using D7 with DOA 4.0.7.1.
At a customer site (an Oracle RAC 10.2.0.4 enterprise under
Linux) I have this strange problem
A TOracleDataset, used to insert in a table, issues
(seeing from OracleMonitor. I am waiting the Oracle trace file from the customer) this statement:
insert into S_NODES_RESP_TEST
(ID, CT_NODES_ORGANIG, CZ_UTENTI, DT_INIZIO, DT_FINE, FL_RICEVI_WF)
values
v1, :v2, :v3, :v4, :v5, :v6)
returning rowid into :doa__rowid
OracleMonitor shows that the variables are:
V1 1
V2 1
V3 1
V4 19/01/2009
V5 21/01/2009
V6 S
DOA__ROWID Null AAAuxZAAjAAAICsAAB
Table S_NODES_RESP_TEST is defined as:
create table S_NODES_RESP_TEST
ID NUMBER(10) not null,
CT_NODES_ORGANIG NUMBER(10) not null,
CZ_UTENTI NUMBER(10) not null,
DT_INIZIO DATE default to_date('1/1/1900', 'dd/mm/yyyy') not null,
DT_FINE DATE default to_date('1/1/3000', 'dd/mm/yyyy') not null,
FL_RICEVI_WF VARCHAR2(1) default 'S'
alter table S_NODES_RESP_TEST
add constraint PK_S_NODES_RESP_TEST primary key (ID);
The problem is the field "FL_RICEVI_WF".
After the insert above and commit it has null value
instead of 'S' value...
I tried a pl/sql block with same parameters and it works ..
I hope that the Oracle trace file will explain ...
Have you ever seen similar a problem ?
Thanks bye
Nicola
values
V1 1
V2 1
V3 1
V4 19/01/2009
V5 21/01/2009
V6 S
Thanks bye
Nicola
