I've got a two different results when i use Test Window for executing procedure. using 7.1.5.1397(96)
I've a procedure which gets data from one table (in cursor) and then checks (by PK) each value of cursor string with the target table if it founds values not equivalent then it makes update. one of values of cursor attribute is making by analytic function LAG, lets call it "flag";
no data change in source table.
when i use "start debugger(ctrl-F9)" -- procedure not making any changes -- it is ok (i said that no data change in source table), but if i pressing F8(execute) -- it change 1 row: value of "flag" (was 4 - now: 1) -- it's not right
then i again press "start debugger(ctrl-F9)" and value of "flag" correct's from "1" to "4": it's ok, and from this moment any execution by "start debugger(ctrl-F9)" -- making no change - it's ok too, but when i execute it by F8 -- it again making data in target table wrong.
I think it is not quite well behaviour of procedure execution, i never see in pl/sql developer before ?
I want to ask Marco to answer this question
sorry for my english -- you can ask me any q's to make situation clear.
thanks
thanks
