Bernhard S
I have created a command window with following test case content to better demonstrate the effect
When executing this I get in the dialog sheet following output:
Hitting enter just adds 4, 5, ...
A semicolon doesn't end the curse either. Only way to end it without quitting PSD is doing something like this:
-- this is a test how a block comment start sign
-- in a line comment affects execution of PSD command window /*
select sysdate from dual;
Connected to Oracle Database 10g Enterprise Edition Release 10.2.0.4.0
Connected as scott
SQL>
3
SQL:
SQL>
3 */;
ORA-00911: Ung
