I have a procedure in a package:
But I can't figure out how to access this proc using doad, if I only have execute-rights to the package. When running as dba there is no problem (other than the obvious security-problem
When executing the code below, i get a "ORA-00942: table or view does not exists" at "LOBLocator.Size" (What is TLobLocator doing in my tables?):
[This message has been edited by Lauritz (edited 12 November 1999).]
Code:PROCEDURE GetObject(p_id IN number, o_state OUT number, p_object OUT blob) IS BEGIN select o_state, o_object into p_object from t_object where o_id=p_id; END GetObject;
Code:OracleQuery:=TOracleQuery.Create(self); OracleQuery.Session:=OracleSession; OracleQuery.SQL.Clear; OracleQuery.SQL.Add('BEGIN'); OracleQuery.SQL.Add('SOMEUSER.SOMEPACKAGE.GETOBJECT(:P_ID, :P_STATE, :P_OBJECT);'); OracleQuery.SQL.Add('END;'); OracleQuery.DeleteVariables; OracleQuery.DeclareVariable('P_ID', otInteger); OracleQuery.DeclareVariable('P_STATE', otInteger); OracleQuery.DeclareVariable('P_OBJECT', otBlob); OracleQuery.SetVariable('P_ID', 1); LOBLocator:=TLOBLocator.Create(OracleSession, otBLOB); OracleQuery.SetComplexVariable('P_OBJECT', LOBLocator); OracleQuery.Execute; ShowMessage('You will see this dialog: '+IntToStr(OracleQuery.GetVariable('P_STATE'))); ShowMessage('You will *not* see this dialog: '+IntToStr(LOBLocator.Size)); LOBLocator.Free; OracleQuery.Free;
