Hi Marco
We have problem with security and plsqldeveloper 9 - problem with stored connection and password list.
Problem is that passwords and connection strings are stored in user.prefs. This passwords in prefs are encrypted which is good. But if someone copy this user.prefs to his computer he will be able to connect to all stored connections with username and passwords stored here, which is problem. I believe that solution will be to give there higher security level. I mean another master password to this user.prefs after which connection list will open.
So it can work this way
Ill open plsqldeveloper, it will ask me for user defined master password. If this password will be ok it will open connection list for me (if it will be wrong connection list will be empty) and it will be open all the time till Ill close plsqldeveloper instance. If Ill open new instance it will ask me for master password again.
Will this be possible?
Thanks for your reply
Pavel
Pavel
