Stand alone beautifier
Volker
Enhancement request (I think): is it possible to use the plsql beautifier as a standalone program or with special command line options?
thanks,
Volker
Yes. You can use the "BEAUTIFY FILE | OBJECT" command in a Command Script. This script can be executed through PL/SQL Developer from the Windows Command Line.
I tried
plsqldev.exe nologon commandfile="c:\beautify.plsql" test.sql
with beautify.plsql as
SET BEAUTIFIERRULES "C:\temp\PLSQLLayout.br"
BEAUTIFY %1
PLSQLDeveloper starts an loads the file test.sql. But the file will not beautified and saved; PLSQLDeveloper is open and waits.
You cannot pass parameters to the command script. A script like this would work:
BEAUTIFY test.sql
EXIT APPLICATION
