sql & xml
Roberto
i would to create a xml file containing data extract with a sql query, but xml file must respect a specific dtd (and not the generic schema that i obtain whit the export of the grid).
Is the first time that i must export data in a xml and...i'm very confused
i work with oracle 8.1.7 and pl/sql dev 5.1 version
someone has some suggestion in order to help me??
thanks
Roberto
Roberto,
You should be able to use PL/SQL functions like XMLElement, XMLForest, and XMLSequence to formulate your data into a single XML column. PL/SQL Dev can be used to export the data if you want, but its XML capabilities are mostly for extracting and viewing data.
Kerry
i've find something on the web around this function (XMLElement, XMLForest, etc...) but with my oracle 8.1.7 i do not succeed to use them...there is a way to see if this function are included? If there aren't, how i can install this function?
Roberto
with a server test, i've migrate on oracle 9.2 and on my pc client i've installed oracle client 9.2 with all XML option.
Now i've tried to execute a query in this style
select XMLElement("Emp",
XMLAttributes(e.employee_id AS "ID", e.last_name),
XMLElement("Dept",e.dept),
XMLElement("Salary",e.salary)) AS "Emp Element"
from emps e where e.employee_id = 206
Now the query don't return errors, but the result is nothing, the part of sql-windows where appears the result is empty, what's could be the problem???
If i try a simple query like this
select XMLElement ("employee", e.employee)
from employee e
in pl/sql or sql*plus on my PC, there is no result,
if i try this query direcly in the sql*plus on the server the result are correct
Roberto
P.s.: scuse me from my english :-))))
In PL/SQL Developer 5.1 you will have to apply the getclobval() function:
select XMLElement ("employee", e.employee).getclobval()
from employee e
PL/SQL Developer 6.0 will automatically get the XML text from the XMLTYPE instance. See chapter 6.7 in the User's Guide for more details.
