K Kishu Member² Feb 21, 2018 #1 When i try to save SQL Window, The following Error pop ups, Can't Create file "E:1.sql". The system cannot find the path specified .
Marco Kalter Administrator Staff member Feb 21, 2018 #1 The filename does indeed not seem correct. You cannot use a : character in a filename.
K Kishu Member² Feb 21, 2018 #1 Actually file name is only 1.sql, what i've mentioned is error showing with the path
Marco Kalter Administrator Staff member Feb 22, 2018 #1 Why does it go to E: ? Is that the location where you are saving the file?
