SQL Window Query Resize
phocai
Hello.
In v7 (7.0.1.1066) the query portion of the SQL Window no longer resizes to query contents when the 'Align Result Grid' button is clicked. I used this feature a lot and am missing it badly. Will you please bring it back?
Thanks!
I haven't used that feature much before. How do you expect it to work? I'm running the same version and if I manually resize a column and then click the button it resizes the columns back to my preference (header and data).
It does not change the number of rows displayed. Is that what you were expecting?
Best,
It works fine for resizing columns in the result set. What it doesn't do anymore is resize the *upper* half of the SQL window where the query is. In v6 (which I still have installed on another PC) the query edit window will increase or shrink depending on the size of the statement. It doesn't do that in v7 anymore. If you have a long query you have to resize the window manually.
