I have a query that returns the first three records and then hangs. The only way to resolve the issue is to close the window and choose to terminate the query.
The same query in SQL/Plus returns all 57 records in 2 seconds.
This query is using object types and calling a couple of constructors.
I did turn on the debugger while the query was executed. Here is information from the Debug.txt:
4/10/2008 8:34:51 AM AddNavigationBookmark starts
4/10/2008 8:34:51 AM AddNavigationBookmark GNV00004
4/10/2008 8:34:51 AM NavigationBookmarks.EnableButtons(Rebuild)
4/10/2008 8:34:51 AM NavigationBookmarks: Backward=4, Forward=0
4/10/2008 8:34:51 AM AddNavigationBookmark ends
4/10/2008 8:34:54 AM SQLForm Initializing...
4/10/2008 8:34:54 AM SetConnected starts
4/10/2008 8:34:54 AM SetConnected: Connect starts
4/10/2008 8:34:54 AM TOracleSession $016C3610 Start Session.LogOn as cisd@DEV
4/10/2008 8:34:55 AM TOracleQuery Query Start Query.Execute
4/10/2008 8:34:55 AM TOracleQuery Query End (1 record processed)
Duration = 0
4/10/2008 8:34:55 AM TOracleSession $016C3610 End
Duration = 1.062
4/10/2008 8:34:55 AM SetConnected: (Dis)connect ends
4/10/2008 8:34:55 AM SetSessionAction starts: SQL Window - SELECT CIS_Consultant_Firm_Obj( CCF_Consultant_Id, CIS_Access_Obj( 324397396, 328079246)) FROM C ...
4/10/2008 8:34:55 AM TOracleQuery $02AD2E20 Start Query.Execute
SQL = select null from dual
4/10/2008 8:34:55 AM TOracleQuery $02AD2E20 End (1 record processed)
Duration = 0
4/10/2008 8:34:55 AM TOracleQuery BytesPerCharacterQuery Start Query.Execute
4/10/2008 8:34:55 AM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.016
SQL = select lengthb(nchr(20000)), nchr(20) from dual
Duration = 0
:ACTION = SQL Window - SELECT CIS_Consultant_Firm_Obj( CCF_Consultant_Id, CIS_Access_Obj( 324397396, 328079246)) FROM C ...
Duration = 0
4/10/2008 8:34:55 AM SetSessionAction ends
4/10/2008 8:34:55 AM ExecuteConnectScript starts
4/10/2008 8:34:55 AM ExecuteConnectScript ends
Duration = 0
4/10/2008 8:34:55 AM EnableOutput starts
4/10/2008 8:34:55 AM TOracleQuery PLSQLDevForm.EnableOutputQuery Start Query.Execute
SQL = begin
if :enable = 0 then
sys.dbms_output.disable;
else
sys.dbms_output.enable
size);
end if;
:ENABLE = 1
:SIZE = 1000000
4/10/2008 8:34:55 AM TOracleQuery PLSQLDevForm.EnableOutputQuery End
Duration = 0
4/10/2008 8:34:55 AM EnableOutput done
4/10/2008 8:34:55 AM InitStatistics starts
4/10/2008 8:34:55 AM TOracleQuery PLSQLDevForm.StatQuery Start Query.Execute
SQL = select value from v$sesstat where sid = :sid order by statistic#
:SID = 144
4/10/2008 8:34:55 AM TOracleQuery PLSQLDevForm.StatQuery End (258 records processed)
Duration = 0.015
4/10/2008 8:34:55 AM InitStatistics ends
4/10/2008 8:34:55 AM NavigationBookmarks.EnableButtons(Rebuild)
4/10/2008 8:34:55 AM NavigationBookmarks: Backward=4, Forward=0
4/10/2008 8:34:55 AM SQLForm Executing...
4/10/2008 8:34:55 AM TSQLThread SQLThread.Execute
:ID = Null
Duration = 0
4/10/2008 8:34:55 AM TOracleQuery $02AD3500 Start Query.Execute
SQL = SELECT
CCF_Consultant_Id,
FROM
CIS_Consultant_Firm
WHERE
CCF_Consultant_Id >= 800
4/10/2008 8:34:57 AM TOracleQuery $02AD3500 End (57 records processed)
Duration = 2.235
4/10/2008 8:34:57 AM TOracleQuery SQLForm.TestQuery Start Query.Describe
SQL = SELECT * FROM CIS_Consultant_Firm
4/10/2008 8:34:57 AM TOracleQuery SQLForm.TestQuery End
Duration = 0
4/10/2008 8:34:57 AM TOracleObject Start Object.Create('CISD.CIS_CONSULTANT_FIRM_OBJ', '')
4/10/2008 8:34:57 AM TOracleObject End
Duration = 0
4/10/2008 8:34:57 AM TOracleObject Start Object.Create('CISD.CIS_STATUS_NTBL', '')
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
4/10/2008 8:37:34 AM TOracleQuery Query Start Query.Execute
SQL = select * from v$version
4/10/2008 8:37:34 AM TOracleQuery Query End (5 records processed)
Duration = 0
4/10/2008 8:37:38 AM TOracleQuery Query Start Query.Execute
4/10/2008 8:37:38 AM TOracleQuery Query End (5 records processed)
Duration = 0
4/10/2008 8:37:38 AM TOracleQuery $02AD2A00 Start Query.Execute
SQL = select * from nls_database_parameters where parameter like 'NLS%CHARACTERSET'
4/10/2008 8:37:38 AM TOracleQuery $02AD2A00 End (2 records processed)
Duration = 0
4/10/2008 8:38:39 AM AddPlugInPopups Start 1
4/10/2008 8:38:39 AM PL/SQL Documentation (plsqldoc)
4/10/2008 8:38:39 AM VIEW+
4/10/2008 8:38:39 AM MATERIALIZED VIEW+
4/10/2008 8:38:39 AM PACKAGE+
4/10/2008 8:38:39 AM PACKAGE BODY+
4/10/2008 8:38:39 AM TABLE+
4/10/2008 8:38:39 AM TYPE+
4/10/2008 8:38:39 AM TYPE BODY+
4/10/2008 8:38:39 AM FUNCTION+
4/10/2008 8:38:39 AM PROCEDURE+
4/10/2008 8:38:39 AM TRIGGER+
4/10/2008 8:38:39 AM PROGRAMWINDOW
4/10/2008 8:38:39 AM AddPlugInPopups End
4/10/2008 8:38:39 AM TOracleQuery $02AD2A00 Start Query.Execute
4/10/2008 8:38:39 AM TOracleQuery $02AD2A00 End (1 record processed)
Duration = 0
4/10/2008 8:38:39 AM TOracleQuery PLSQLDevForm.ResolveSymbolQuery Start Query.Execute
SQL = declare
t_owner varchar2(30);
t_name varchar2(30);
procedure check_mview is
dummy integer;
if
bject_type = 'TABLE' then
select 1 into dummy
from sys.all_objects
where owner =
bject_owner
and object_name =
bject_name
and object_type = 'MATERIALIZED VIEW'
and rownum = 1;
bject_type := 'MATERIALIZED VIEW';
end if;
exception
when others then null;
:sub_object := null;
if :deep != 0 then
if
art2 is null then
into
bject_type,
bject_owner,
bject_name
from sys.all_constraints c
where c.constraint_name =
art1 and c.owner = :cur_schema
and rownum = 1;
else
select constraint_type, owner, constraint_name,
art3
into
bject_type,
bject_owner,
bject_name, :sub_object
art2 and c.owner =
art1
and rownum = 1;
end if;
if
bject_type = 'P' then
bject_type := 'PRIMARY KEY'; end if;
if
bject_type = 'U' then
bject_type := 'UNIQUE KEY'; end if;
if
bject_type = 'R' then
bject_type := 'FOREIGN KEY'; end if;
if
bject_type = 'C' then
bject_type := 'CHECK CONSTRAINT'; end if;
return;
exception
when no_data_found then null;
end if;
:sub_object :=
art2;
if
part2 is null) or
part1 != :cur_schema) then
select object_type, :cur_schema,
art1
into
bject_type,
bject_owner,
bject_name
where owner = :cur_schema
and object_name =
art1
and object_type in ('MATERIALIZED VIEW', 'TABLE', 'VIEW', 'SEQUENCE', 'PROCEDURE', 'FUNCTION', 'PACKAGE', 'TYPE', 'TRIGGER', 'SYNONYM')
and rownum = 1;
if
bject_type = 'SYNONYM' then
select s.table_owner, s.table_name
into t_owner, t_name
from all_synonyms s
where s.synonym_name =
art1
and s.owner = :cur_schema
and rownum = 1;
select o.object_type, o.owner, o.object_name
into
bject_type,
bject_owner,
bject_name
from sys.all_objects o
where o.owner = t_owner
and o.object_name = t_name
and rownum = 1;
end if;
:sub_object :=
art2;
if
art3 is not null then
:sub_object := :sub_object || '.' ||
art3;
end if;
check_mview;
return;
exception
end if;
from all_synonyms s
art1
and s.owner = 'PUBLIC'
and rownum = 1;
into
bject_type,
bject_owner,
bject_name
and rownum = 1;
check_mview;
return;
exception
:sub_object :=
art3;
into
bject_type,
bject_owner,
bject_name
where o.owner =
art1
and o.object_name =
art2
and rownum = 1;
check_mview;
return;
exception
if
art2 is null and
art3 is null
then
select 'USER', null,
art1
into
bject_type,
bject_owner,
bject_name
from sys.all_users u
where u.username =
art1
and rownum = 1;
return;
end if;
exception
if
art2 is null and
art3 is null and :deep != 0
then
select 'ROLE', null,
art1
into
bject_type,
bject_owner,
bject_name
from sys.session_roles r
where r.role =
art1
and rownum = 1;
return;
end if;
exception
bject_owner := null;
bject_type := null;
bject_name := null;
ART1 = WHERE
:OBJECT_TYPE = TABLE
:OBJECT_OWNER = CIS
:OBJECT_NAME = CIS_CONSULTANT_FIRM
ART2 =
:SUB_OBJECT = Null
ART3 =
EEP = 1
:CUR_SCHEMA = CISD
4/10/2008 8:38:39 AM TOracleQuery PLSQLDevForm.ResolveSymbolQuery End
Duration = 0.015
4/10/2008 8:38:43 AM Aborting thread
4/10/2008 8:38:45 AM TOracleQuery Query Start Query.Execute
:ID = Null
4/10/2008 8:38:45 AM TOracleQuery Query End
Duration = 0
4/10/2008 8:38:45 AM NavigationBookmarks.EnableButtons(Rebuild)
4/10/2008 8:38:45 AM NavigationBookmarks: Backward=4, Forward=0
PL/SQL Developer Info:
PL/SQL Developer
Version 7.1.3.1381
01.44401 - Unlimited user license
Physical memory : 1,038,404 kB (518,492 available)
Paging file : 2,512,108 kB (2,117,868 available)
Virtual memory : 2,097,024 kB (2,001,272 available)
Parameters
debugsql
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
C:\Documents and Settings\A0278\Application Data\PLSQL Developer\Preferences\a0278\default.ini
Plug-Ins
*PL/SQL Documentation (plsqldoc) (C:\Program Files\PLSQL Developer\PlugIns\plsqldoc.dll)
(* is Active)
Aliases
brdgms
comm
dbadm
dev
dev9ir2
Homes
DEFAULT_HOME (C:\orant)
Des9i (C:\Des9i)
Ora10g (C:\Ora10g)
ora9i (c:\orant\ora9i)
DLLs
c:\orant\ora9i\bin\oci.dll
TNS File
c:\orant\ora9i\Network\Admin\tnsnames.ora
Using
Home: ora9i
DLL: c:\orant\ora9i\bin\oci.dll
OCI: version 9.2
Oracle9i Enterprise Edition Release 9.2.0.7.0
Character Sets
Character size: 1 byte(s)
CharSetID: 1
NCharSetID: 2000
Unicode Support: True
NLS_LANG: AMERICAN_AMERICA.WE8MSWIN1252
NLS_CHARACTERSET: US7ASCII
Any help would be appreciated.
Jenean Spencer
JS Programming, LLC
Duration = 0
Duration = 1.062
Duration = 0
Duration = 0.016
Duration = 0
Duration = 0
Duration = 0
SQL = begin
if :enable = 0 then
else
end if;
:ENABLE = 1
:SIZE = 1000000
Duration = 0
:SID = 144
Duration = 0.015
:ID = Null
Duration = 0
SQL = SELECT
CCF_Consultant_Id,
FROM
CIS_Consultant_Firm
WHERE
Duration = 2.235
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
SQL = declare
dummy integer;
if
select 1 into dummy
where owner =
and object_name =
and rownum = 1;
end if;
exception
if :deep != 0 then
if
into
and rownum = 1;
else
into
and rownum = 1;
end if;
if
if
if
if
return;
exception
end if;
:sub_object :=
if
into
and object_name =
and rownum = 1;
if
from all_synonyms s
and rownum = 1;
into
and rownum = 1;
end if;
:sub_object :=
if
end if;
check_mview;
return;
exception
end if;
from all_synonyms s
and rownum = 1;
into
and rownum = 1;
check_mview;
return;
exception
:sub_object :=
into
where o.owner =
and o.object_name =
and rownum = 1;
check_mview;
return;
exception
if
then
into
where u.username =
and rownum = 1;
return;
end if;
exception
if
then
into
where r.role =
and rownum = 1;
return;
end if;
exception
:OBJECT_OWNER = CIS
:SUB_OBJECT = Null
:CUR_SCHEMA = CISD
Duration = 0.015
:ID = Null
Duration = 0
PL/SQL Developer
Version 7.1.3.1381
Parameters
debugsql
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
(* is Active)
Aliases
brdgms
comm
dbadm
dev
dev9ir2
Homes
Des9i (C:\Des9i)
Ora10g (C:\Ora10g)
DLLs
TNS File
Using
Home: ora9i
OCI: version 9.2
Character Sets
CharSetID: 1
NCharSetID: 2000
Jenean Spencer
JS Programming, LLC
