Edwin Teisman
I would like to see two features added to the SQL Window:
1. An Shortcut key with which I can quickly navigate from the query result records back to the sql above this.
Currently if I decide to modify the SQL used, it requires me to hange the focus using my mouse.
As an experienced programmer I am very keyboard focussed.
2. The SQL part of the SQL window becomes 3 lines
high if the sql is a one-line query like
"select * from table"
If there any way so I can change this default to a minimum of say 12 lines or more?
I have an 22 inch screen so I have space enough.
Now I am very often required to resize the sql window, using my mouse.
Both these features would be handy because I very ofter write some SQL, try it, change it, try it again, etc.
By the way, great tool!
(*PLSQLDev version 7.0.1.1066*)
