SQL Trace output not showing
After enabling SQL Trace and running a script in the test window, there is no output in the trace window. How can I get this output to show?
Unfortunately Oracle has 2 tuning features that have the word "Trace" in its name.
One is SQL Trace, which can be enabled in the Session menu. When enabled, all server processing caused by a SQL Window or Test Window will be logged in a trace file on the database server. One condition is that the timed statistics parameter of the database instance you are using must be set to true. You can view the information in the trace file by using Oracle's tkprof utility on the database server.
The other is the dbms_trace facility, which can be enabled in the Test Window by pressing the corresponding button on the Test Window toolbar. After execution of the Test Window you can switch to the Trace tab page to view the trace report.
I hope this helps.
