sql history (ctrl+e) does not work anymore ?
mbo
There is a shortcut "ctrl+e" that gives the list of all sql commands issued.
I never found the corresponding menu command but it worked on my former machines. It is not the case anymore.
How can I acces to the list of sql command issued in a sql window ?
Mbo
You use the "Recall Statement" item from the "Edit" menu.
To assign a function key, go to Tools > Preferences > Key Configuration and assign a key to "Edit / Recall Statement".
