SQL command not properly ended...
aidenf
I am new to PL/SQL Developer. I think I have a simple question that many of you can help me with. We use PowerDesigner for data modeling and the SQL script that it generated uses the forward slash symbol '/' for statement execution. Unlike SQL*Plus, it seems like PL/SQL Developer does not support such symbol for statement execution. We do not want to modify the script generated by PowerDesigner. The error message that we are getting from PL/SQL Developer is ORA-00933 SQL command not properly ended.
Example of the script:
drop indes TEST.FKxxx
Thanks!
Aiden Fung
Hi Aiden,
Try the Command Window instead of the SQL window.
The SQL Window gives you single execution with grid results.
The Command Window gives you SQL*Plus clone capabilities. See manual as to which commands are supported.
