sql and test window behavior when typing in PSD12
Albert
Hello!
Suugest that we have a plsql block in sql (or test) window. For example:
declare
  v_tr_file_name V$DIAG_INFO.NAME%type;
  select i.value into v_tr_file_name FROM V$DIAG_INFO i WHERE NAME = 'Default Trace File';
When we type one character (for example changing variable "v_tr_file_name" in "select" statement) we can see that PSD executes such statements. But it do this work for EVERY typed character
declare
  t_owner varchar2(30);
  t_name  varchar2(30);
  procedure check_mview is
    dummy integer;
    if :object_type = 'TABLE' then
      select 1 into dummy
      from sys.dba_objects
      where owner = :object_owner
      and object_name = :object_name
      and object_type = 'MATERIALIZED VIEW'
      and rownum = 1;
      :object_type := 'MATERIALIZED VIEW';
    end if;
  exception
    when others then null;
  :sub_object := null;
  if :deep != 0 then
      if :part2 is null then
          from sys.dba_constraints c
         where c.constraint_name = :part1 and c.owner = :cur_schema
           and rownum = 1;
      else
        select constraint_type, owner, constraint_name, :part3
         where c.constraint_name = :part2 and c.owner = :part1
           and rownum = 1;
      end if;
      if :object_type = 'P' then :object_type := 'PRIMARY KEY'; end if;
      if :object_type = 'U' then :object_type := 'UNIQUE KEY'; end if;
      if :object_type = 'R' then :object_type := 'FOREIGN KEY'; end if;
      if :object_type = 'C' then :object_type := 'CHECK CONSTRAINT'; end if;
      return;
    exception
      when no_data_found then null;
  end if;
  :sub_object := :part2;
  if (:part2 is null) or (:part1 != :cur_schema) then
      select object_type, :cur_schema, :part1
      where owner = :cur_schema
      and object_name = :part1
      and object_type in ('MATERIALIZED VIEW', 'TABLE', 'VIEW', 'SEQUENCE', 'PROCEDURE', 'FUNCTION', 'PACKAGE', 'TYPE', 'TRIGGER', 'SYNONYM')
      and rownum = 1;
      if :object_type = 'SYNONYM' then
        select s.table_owner, s.table_name
          into t_owner, t_name
          from dba_synonyms s
         where s.synonym_name = :part1
           and s.owner = :cur_schema
           and rownum = 1;
        select o.object_type, o.owner, o.object_name
          from sys.dba_objects o
         where o.owner = t_owner
           and o.object_name = t_name
           and rownum = 1;
      end if;
      if :part3 is not null then
        :sub_object := :sub_object || '.' || :part3;
      end if;
      check_mview;
      return;
    exception
  end if;
      from dba_synonyms s
       and s.owner = 'PUBLIC'
       and rownum = 1;
       and rownum = 1;
    check_mview;
    return;
  exception
  :sub_object := :part3;
     where o.owner = :part1
       and o.object_name = :part2
       and rownum = 1;
    check_mview;
    return;
  exception
    if :part2 is null and :part3 is null
    then
      select 'USER', null, :part1
      from sys.dba_users u
      where u.username = :part1
      and rownum = 1;
      return;
    end if;
  exception
    if :part2 is null and :part3 is null and :deep != 0
    then
      select 'ROLE', null, :part1
      from sys.session_roles r
      where r.role = :part1
      and rownum = 1;
      return;
    end if;
  exception
  :object_owner := null;
  :object_type := null;
  :object_name := null;
:PART1=['V$DIAG_INFO']
:OBJECT_TYPE=['VIEW']
:OBJECT_OWNER=['SYS']
:OBJECT_NAME=['V_$DIAG_INFO']
:PART2=['']
:SUB_OBJECT=[NULL]
:PART3=['']
:DEEP=[0]
:CUR_SCHEMA=['SYS']
select column_name, nullable, data_type, data_type_mod, data_type_owner, data_length, data_precision, data_scale, char_used, char_length
from sys.dba_tab_columns
where owner = 'SYS'
and table_name = 'V_$DIAG_INFO'
order by column_id
select comments from sys.dba_tab_comments
   and table_name = :object_name
Is it normal?
My preferences for code assistant:
describe users=true
describe context (3 chars)=true
include columns from dml=true
describe standart functions =true
show in popup=false
Thank you
I think this is most likely caused by the "Include columns from DML statements" option of the Code Assistant. Can you disable it and try again?
However, the code above should only execute once when typing within the context of a DML statement. We'll look into this.
