spool out from PL/SQL Dev
ccrist
Anyone know a way to get around the 1,000,000 byte restriction (we're in 9i) of the dbms_output feature?
Would like a way to spool out to a file if possible.
TIA!
-c.
How about using a Test window and using:
htp.print('
[your code, using htp.print() instead of dbms_output.put_line()]
htp.print('
Then just look on the "HTP output" tab. Right-click, "View source" will let you save to file. Or if you really want to spool, add some code that reads the htp buffer using OWA.get_line()/OWA.get_page() and uses UTL_FILE to write to a file.
