deniskolesnikov
Hi Marco,
I've encountered an unpleasant feature:
when I open a function/procedure from database into plsqldev's program window
it splits lines longer than 255.
sometimes it may cause errors
say there's a function:
create or replace function f_tmp return varchar2 is
result varchar2(30);
result:=ltrim(replace('1111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111 11111111111111111111111111111','1',' '))| |to_char(sysdate,'dd.mm.yyyy hh:mi:ss');
return result;
when it's opened from the database it becomes
create or replace function f_rm_tmp return varchar2 is
i:ss');
return result;
then if I press execute then the function in the database gets distorted
and when used produces the error:
ORA-01821: data format not recognized
plsqldev v.5.1.2.682;
Best Regards, Denis
return result;
i:ss');
return result;
Best Regards, Denis
