Special Charachter Problem
When I set
NoUnicodeSupport := true;
I got Ora-03130.
Then setting NLS_LANG in registry back to AMERICAN_AMERICA.WE8MSWIN1252
seems to fix the issue.
It's a bit confusing since Oracle encourages the standard use of UTF-8 character set.
Have you set TOracleSession.BytesPerCharacter to bcAutoDetect?
Also note that if you want to display Unicode characters, you need to use data-aware controls that support Unicode like the TNT Controls.
The setting of bcAutoDetect makes no difference.
I do not want to display unicode characters, just special ASCII characters.
Now I get an ORA-12899 - value too large for column
when a field contains special characters and reaches the limit. If I insert the same string with an SQL tool it works.
Can you try the following? Before or shortly after a connection is made in your application, set the global Oracle.NoUnicodeSupport to True.
